3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Exclamation mark and unknown status
11 REPLIES 11
Message 1 of 12
5626 Views, 11 Replies
Hi all
all my last files in the asset tracking i have in the status an unknows status imstead of found or o.k for maps ...
the parth is o.k
someone know why??
ive attached a screenshot.
thanks!
11 REPLIES 11
Message 2 of 12
Steve_Curley
From the Max help...
[exclamation mark icon here] "Status for the file could not be obtained. This typically means you are not logged into the provider."
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 12
BenBisares
in reply to: Steve_Curley
Just to add to Steve_curley's response, does your project use any kind of asset management system like Vault? Also what version of 3ds Max are you using?
Ben Bisares
Message 4 of 12
hey steve what do you mean by : not logged into the provider??
you mean by starting 3dsmax as administrator?
Message 5 of 12
in reply to: BenBisares
hey ben im using 3dsmax design 2014 and its happend in any project i used or model or anything else i dotn have in the status "found" any more..
just unsknoun status
Message 6 of 12
Steve_Curley
That was a direct quote from the help. I didn't say it - the help says it. The "provider" is an asset tracking system such as Vault. Beyond that I know nothing about it.
Max 2016 (SP1/EXT1)
Message 7 of 12
Stefan_L
Since using a renderfarm service (REBUSfarm) and installing their scripts, I too have these exclamation marks.
Optically annoying, but less important than the "Status" column, which is too narrow in your screenshot.
Behind the "status unknown" it tells things like:
"missing" (if not found)
"found" (if found elsewhere)
or nothing, if found in the right place Smiley Happy
Stefan
i7-2600 @ 3,4GHz, 32GB Ram,
512+128GB SSDs + 2x500GB HD
GeForce GTX 980 Ti 6GB + GTX 980 4GB
latest Driver (almost always)
Win7ProX64 SP1
Message 8 of 12
alex1560
in reply to: Stefan_L
You must go to Options inside Asset Tracking and click on "Disable Asset Tracking".
Message 9 of 12
The comments by @Steve_Curley and @BenBisares are correct when referring to Vault protection, and @alex1560 is also correct in that unchecking "Disable asset tracking" will also produce these ! marks.  Marking solutions in this post so future users can benefit from this, thank you all for the excellent posts.
Best Regards,
Message 10 of 12
hakan
in reply to: alex1560
you are the hero man thanks so much...
Message 11 of 12
I can confirm that this behavior is most likely caused by asset management software. After I installed "Project Manager" from Kstudio Ihad the same behaviour - all marked as "Unknown status", even after uninstalling the software for test reasons. Options --> Disable Asset Tracking is the solution! Thanks!
Workstation: Ryzen 9 5950x@ 4,20GHz 64 GB RAM, Nvidia Quadro P5000, Win10 Prof.
Rendernode: AMD Threadripper 2990wx@ 3,20 GHz 64 GB RAM, Win 10 Prof.
Autodesk Building Design Suite Premium 2021, VRay 5, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
Message 12 of 12
ronilson3d
estou com o mesmo problema
"I have the same problem"
Translated by Google
Traduzido por [@clacampos] através do Google Tradutor
