I know this is stupid, but i dont have a middle mouse button. I am trying to change it so that to pan, i hold lmb (plus somethingvelse like alt if i need tp) and rotate by holding rmb (plus whatever again) it wont let me do this or maybe im not doing it correctly, any help? Thanks so much.
Click on "Customize" menu, select "Customize user interface", select "Mouse" tab, on the right side there is as "Shortcut" field where you define a shortcut you want to use, then on the left side select which command you want it to perform and click "Assign".
