I have Created a polygon using Spline(Line) Then used a shell Modifier to Fillout the polygon and set the outter amount to 0.01. The Problem that i am facing is while creating Hole in that Polygon Plane When I create a single Hole using Boolean it is created perfectly when after creating the first hole when i create a second hole the Second hole is also created but filling the first hole now I just hove one hole instead of 2 hole
Is there any way to create multiple holes in a plane or any other way to create to do the same.
Solved by LenDoublet. Go to Solution.
First there are as many ways creating a hole in plane as there are users out there 🙂 It's hard to say what's going wrong with your Boolean operation or what you are trying to accomplish in the end.
Using the Boolean operation you have to be cautious with coplanar faces and vertices. Maybe a Retriangulate in an Edit Poly modifier on top of your current object fixes your problem.
If you want to make a plane out of a spline with a hole in it, it would be a way to build the hole right into your spline. Just draw your hole shape like you did with the line tool and attach it to the first spline. (watch out for intersections)
If you just need a poly or plane you can put an edit poly modifier on top of the spline instead of the shell.
