Hi, I have attached images of the issues Im having with Max.
Error Loading Plugin at startup:
and
With the 3ds Max 2015 extension 1 it says installed, but comes up in the updater at least once an hour saying 'uninstalled' and I go through the process again and again, this happens on two different machines, one at work and one at home.
Do you have 3D Max or 3D Max Design? I've noticed that my application manager will throw up updates for Max Design even tho it's not installed ( I use regular Max). Maybe you installed the wrong version of the extension? Otherwise not sure - hopefully someone can sort this out for you. 🙂
Thanks, I didnt think it would have been that easy to uninstall. Do I just re- install it?
Ok I downloaded the EXT 1 from your website and when I try to install I now get this error. If I continue the installation just freezes.
So the Error actually has a number - Error 127, I would assume if it has a number its known and can be fixed somehow. If "the precedure could not be found" is there a way I could get my hands on the Creasemod.DLM file and install it seperately?
For the record my machine at home isnt getting these errors [creasemod and ext 1 install]as it was before, but that is after a clean windows install and Building Suite Install.
I personally haven't encountered this before. I took a look at our defect database and found nothing of note so I'm beginning to this this is a very specific issue.
I would check the following:
-Make sure that you are running 3ds Max under an account with Administrator privileges. If not that it may not be a bad idea to either change the current user permissions or create a new user with admin rights and reinstall 3ds Max
-Also disable any anti-virus/malware programs for testing purposes and during the install process
-Just for curiosities sake can you check and see if you have the "CreaseMod.dlm" file? (C:\Program Files\Autodesk\3ds Max 2015\stdplugs)
I will attempt a reinstall. I am the administrator so that doesnt seem to be the issue, I dont run any anti virus software either. I am now getting more errors with the Autodesk Application Manager for other updates this time an error 1603. I have googled solutions to these problems and tried them all to no result.
I do have creasemod.dlm in the folder.
Yeh still not working, even if I download the files manually and install, the install just freezes, occasionally getting a fatal error msg.
The 3ds max Ext 1 error is now happening on both my machines [home and work] it says its installed then 10 minutes later its back to uninstalled.
Seems like Im not the only one with the problem, I found this thread through a google search:
http://forum.cgpersia.com/f13/autodesk-3dsmax-2015-extension-1-xforce-98657/
Im not sure if there are any solutions in that thread, but at least now I know Im not alone.
Try to install Visual C++ Redistributable Packages for Visual Studio 2013:
http://www.microsoft.com/en-us/download/details.aspx?id=40784
(both x64 and x86)
... and reinstall SP2.
Also you can try extract separately SP2 and Extention from downloaded patch and install SP2 after Extention.
I don't know if you've solved this yourself, but I just wanted to post my solution, in case anyone else had this issue.
I tried to run the EXT installer again, no luck.
So I did what I usually do when things crash with no explanation, delete my Max AppData directory:
C:\Users\<username>\AppData\Local\Autodesk\3ds Max 2015
Voila! No more crease mod error.
