3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Connect 2 vertex to make polygon
1 REPLY 1
GGPS90
906 Views, 1 Reply
Hi, I need to connect these 2 vertex so that I can cap the 2 polygons on the left and right side. How do I do it?
1 REPLY 1
Steve_Curley
in reply to: GGPS90
Can't really see enough of the object to determine where all those edges (connected to the vertices in question) go to. Try the Target Weld - if that refuses to play ball then the reason is because if those vertices were welded it would produce an invalid mesh. The edges would need to be "open" - have a poly on only one side of them - for the weld to work. Would have to see the real object (post the scene, zipped, as an attachment to a reply) to be certain.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
