I am currently upgrade my computer to be able to handle high resolution/object engineering models. I currently have an i5-3450 @ 3.10 GHz, 32 GB of Ram, 250 GB Solid State Drive, and a new 4Gb Quadro K2200. I am currently using 3ds Max 2013. I can move around the camera in the viewport with no issue, but when I go to select all 14,000 objects in a particular file and try rotating them around, the computer comes to a crawl. I have tried 1) switching to different viewport drivers(Nitrous, Direct 3D, Open Gl with Direct 3D having a better result), 2)switching between realistic to shaded to wireframe with no difference.
Does anyone have any input on how I might resolve this issue?
Could this be a hardware issue or a software issue (Is it 3ds Max's settings/programming causing this or just that my computer isn't able to perform at this level yet)?
Is there something I can upgrade even further to be able to rotate 14,000 objects at once (such as in groups), or am I asking for way too much?
Also, I just recently installed the new Quadro card. Is there some kind of settings/performance drivers (besides the latest drivers from Nvidia's webstie) I can install to help me with my issue? My current driver is 340.84
14,000 objects is a lot. You could try grouping, but I'm not sure it would help much. Is it possible to attach them to the same object? Or find a way to not need rotating them all? What kind of objects are they, and why do you need to rotate them all at once?
Chris Medeck
The was model is given to me to work on from a company. It imports default as the front of the model facing down and I'd prefer to work with the model facing forward in the front view. In order to do so, I would need to rotate the model 90 degrees up. So I am given the choice of either selecting a few objects at a time and grouping/merging/collapsing them, or selecting all of them and rotating them for the single purpose. It's not a world ending issue, but brings concerns as to wether it would be hardware issue (my current computer setup) or a software issue (3ds max settings/programming)? Is there any kind of solution that can help me achieve this, or am I just asking for too much?
Just did a test with rotating 15k objects (about 60 Mil. polys) i get about ~1fps using a simple GFORCE GTX680 gaming card.
If you just want to turn around an entire scene where`s the problem? Using transform-type-in it takes a second.
