Dear Autodesk support - the use of the compositor link to AE is critical and helpful, when will you update the plugin to work with the latest Adobe CC ?
At the moment, the link is always broken even in the simplest scenes. In a test scene using 1 camera, 1 point helper and 1 plane, once Creating link in AE giving the "Internal verification error (5027::55)" message followed by "Internal verification Failure (5027::102)" message.
Been trying using either Max 2017 or Max 2014, same results
Thank you
Hello @GeneralCHVGJ,
There have been a few users with similar issues, when a new version is released of CC it is not always compatible with the previous versions. Technically the Max2AE interop is supposed to work up to 2014, so 2015 wasn't part of the original design spec as noted here.
In particular there is a part of 2014 needed for interop that 2015 doesn't ship with. There is a link to a thread here that details how to get around some of this, but it does involve installing 2014 and then updating to 2015. Short version: Install cc 2014, install AE Interop plugin for 3ds max, then install 2015. Please reference the linked thread for details. Please give this a shot and let's see if this solves your problem.
Please hit the "Accept as Solution" button if my post fully solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
I just wanted to follow up here, any progress on your issue?
Best Regards,
Hi Alfred and thank you for the answer and heads up as well. I'll check this workaround out, hope it'll work.
I will keep you posted, Thanks.
Disregarding the mentioned workaround for the issue, I do understand that development and keeping up compatibility are not a simple matter. Yet, does Autodesk 3DS Max development team intends to get into the task of updating the compositor link to the new Adobe CC versions ?
To be honest, I am not privy to the design and development plans of future versions of 3ds Max, so I can't really answer your question about the intentions of the team. I'm sorry for that.
You can install older versions of CC back to CS6 actually, but you have to go to the 'previous versions' tab of the application. It's a bit tricky in my opinion, but here's a link that may help. Please let me know if you have any trouble.
Best Regards,
Best Regards,
Best Regards,
Alfred, you are kind and attentive. Thank you for that. I know you do not have much access to the future development of the software (which is "secret", for legal and economic issues, etc.). But I think there is something very wrong with this Max-AE interaction. After all, these errors exist two years ago. And Autodesk does not seem to move a finger to change that. I do not know if it's a problem more from Adobe or Autodesk, but there is something very wrong with that. If there were serious by the developers to attack once this problem, I think it would be quickly resolved. But the priority is minimal. Anyway, that's it ...
Hello @luizpinto
Thank you for the kind words. That's very kind of you.
I think if a feature is in the software and it doesn't work, it's up to the makers of that software to fix it. Having the CC API change every year can't help here I'm sure, but in the end this is something that would be up to Autodesk to correct. I'm going to go ahead and log this and I will make a note of this thread and your comments in the bug report, and thanks for your patience.
I'd like to log this with as much detail as possible. If you can list any other information for me to put into the report, I will gladly do so. Thank you very much.
Best Regards,
Thanks for pointing that out, I didn't mean to address that to the wrong person.
The best I can do on my end is make a note in the bug tracker and provide workarounds. I'm not in a position to negotiate a relationship with anyone at Adobe on the behalf of Autodesk, but I can (and do) always send information upward to those who are. (And I have brought this up to the KDE and logged into the bug tracker.)
I don't fully agree that it's not supported or useless, it just has a requirement which is CS5-CC2014, as noted in the help. I do see the issue however and I have done what I can on my end.
Best Regards,
Of course, my main goal here is to get users the solutions to their problems and if I cannot do that, escalate issues up the chain. I think leaving this thread open is the right thing to do until this can be addressed. There is a free script that does 3ds Max and AE interop that available out there on scriptspot as a stop gap for the time being. It's called AfterFX Data Exporter and I've used it once or twice. I can't provide support on it since it's 3rd party but it does work pretty well with regular cameras and lights.
Thank you for the kind words, I do appreciate it. In the meanwhile I will post any new information that comes my way when it does.
Best Regards,
hello ,
sir i want to ask you please tell me that compositer will work with after effect cc 2018 & 3d max 2016 ?
please reply me
ateeqrafiq2@gmail.com
