3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Center gizmo after selecting 2 symmetric
3 REPLIES 3
JameyW
709 Views, 3 Replies
Just a quick qustion, how do I get the gizmo to be centered between the 2 edges after selecting them? (the object is symmetrical)
I'm using 3ds max 2014,
Thanks!
3 REPLIES 3
Daf
in reply to: JameyW
Hello! This is done through the Command Panel  - Hierarchy panel Adjust Pivot rollout Affect Pivot Only. In your case select Affect Pivot Only and then click on Center to Object should do it. 🙂
Good article on the Pivot system.
http://docs.autodesk.com/3DSMAX/16/ENU/3ds-Max-Help/files/GUID-6872F014-4785-43D9-A83B-C774507907B3....
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
Steve_Curley
in reply to: Daf
That's for moving the Pivot Point of an object, not for sub-object selections.
On the main Toolbar, the button immediately to the right of the drop-down list which probably says "View". Click and hold until the Flyout appears, select the middle of the 3 options - "Use Selection Center".
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Daf
in reply to: Steve_Curley
oops sorry - misread! Smiley Frustrated
3DS Max 2020.3
