I am VERY new to AutoDesk do I really dont know what I am doing. I am used to Cinema 4D, but AutoDesk is like another universe compred to C4D! I downloaded a model from the internet, and as you can see from the screen-shots below, there are polygons there, but they do not show up in perspective. The model does show up in Render View thankfully, but I need to see it in perspective! Thanks in advance for the help. The project file will linked.
https://www.mediafire.com/?wekrv4ahe1sik2u
-Aphex
Solved by darawork. Go to Solution.
the missing map files shouldnt stop you viewing the mesh in the viewport, what graphics card do you have in your sysem?
This is what it looks like with missing map files.
try starting max in different graphics modes theres nothing wrong with the model you shared
As what AdrianWise8371 said, the missing textures and all shouldnt block me from viewing it... I have a Lenovo IdeaPad P580 with Intel HD Graphics 4000
As you can see from my view, I cannot see the model in perspective or anything...
I really have no idea what you are talking about... Somebody needs to give me steps so I can fix this. As I said, I am new to AutoDesk.
Windows [Start] key -> All Programs -> AutoDesk -> 3D Studio Max -> Change graphics mode.
Even then it may not work correctly for you as you are using low-grade onboard graphics, as opposed to a decent dedicated graphics card.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
