Hey!
When I right click in the Scene Explorer I don't get the quad menu shown in the attached image (from 3ds max Help), instead I get a regular right click menu with other options than in the quad.
Can anyone explain how to get the quad menu?
/Joakim
Solved by a.brown. Go to Solution.
Hi Joakim,
It should work if you right click anywhere inside the scene explorer or layer explorer window. Maybe try loading one of the custom UI schemes?
AB
