Hi all,
I can't run Backburner server as service inside my School Render farm.
That is my Net Structure and Workflow:
School Server.
* Win 2008 Server R2 with Backburner 2014
* Backburner Manager started, OK
* Backburner Monitor started, OK
* Firewall rule to accept conexions by the Backburner servers.
9 PC's with ACSU 2014.
* An special "render" Windows 7 User Account (Not system account) to manage service Logon.
* Backburner server manual start to create backburner.xml inside this account.
* Backburner Monitor accept the connection and show my Server Idle. OK.
* Manual close the server and go to services and CMD to register: serversvc -i
* Registration complete
* I Put my "render" special user account settings, in to Backburner 2014 services -- Properties -- Logon as...
* Restart the PC.
* My monitor shows my Server Absent, but the service is running and started in the configurated computer...
* All Win 7 Accounts are Windows Roaming accounts in to the Win 2008 server.
Any Solution?
You need to edit the Backburner.xml file located under your special user account. C:/Users/*accountname*/AppData/Local/backburner. When you ran the Server locally to "create" the XML, it created the XML file under the user account you were logged in as.
Chris Medeck
I change xml in C:/Users/*accountname*/AppData/Local/backburner. but works
The Backburner Manager write this lines in Log...
2013/10/03 19:22:13 INF Starting Network Manager 2013/10/03 19:22:13 INF <AdapterInfo> 2013/10/03 19:22:13 INF <Name>Command Line Tool</Name> 2013/10/03 19:22:13 INF <Version>300</Version> 2013/10/03 19:22:13 INF <Description>Command Job Adapter v2014</Description> 2013/10/03 19:22:13 INF </AdapterInfo> 2013/10/03 19:22:13 INF Loading plugin: Command Job Adapter v2014 from Backburner Adapter Plugin 2013/10/03 19:22:13 INF Job 'Untitled' added to the queue 2013/10/03 19:22:14 INF New client 192.168.1.4 added to client list 2013/10/03 19:22:14 INF Wiretap interface connected to the local manager 2013/10/03 19:22:14 ERR Could not bind private multicast socket on 'eth0' '192.168.1.4:7555/224.0.0.1/1': An attempt was made to access a socket in a way forbidden by its access permissions. 2013/10/03 19:22:14 ERR Could not bind private multicast socket on 'lo' '127.0.0.1:7555/224.0.0.1/1': An attempt was made to access a socket in a way forbidden by its access permissions. 2013/10/03 19:22:25 INF New client 192.168.1.4 added to client list 2013/10/03 19:22:52 ERR Unable to connect to 192.168.1.22: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. (0x274c). 2013/10/03 19:22:52 ERR Error 0000274C connecting to a01pc02
Thank's
in a way forbidden by its access permissions"
This line leads me to believe there is a problem with the permissions of the account your are using to render. It may not have rights to access the folders it needs on the local machine.
Chris Medeck
Not sure because I don't use the service, but I guess you have to configure the service to run as the user of the machine so it have the same rights. By default, it may run as system account ?
Camedeck: The render slave servers have all Read/Write permisions to the Render forlders. The render user account does not a system account.
I try to change the render user account to another permission group in the server domain and try.
Nicolas: The account is Admin User account, and I configure the service to start with this user account. The Permission rights are ok to the folder.
I try another solution.
be sure it have same network drive connections/letters (for maps, etc) as other account submitting scenes ?
Yes Nicolas, All user accounts (Admin or User) have the same mapped network drive letters to prevent maps/xref conflict.
Now I open a server client backburner render in a machine without service installed and Queue Monitor show me the server in all servers, but is "Absent"... This Machine user account is inside de domain, and I try with other machine logged as user out the domain and I can't see the server in Queue Monitor...
I can't understand...
