Hi everyone,
When I move my cursor on a tool, for example the selection tool, 3ds Max will display the name for that tool "Selection Tool". How do I make 3ds Max display the hotkey for that tool as well?
Thanks in advance.
Solved by darawork. Go to Solution.
You can vote for that feature here: http://3dsmaxfeedback.autodesk.com/forums/76763-small-annoying-things/suggestions/1685073-keyboard-s...
I can't seem to find a script to do it, I thought somebody might have made one.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Another way may be using the search tool ( new in Max 2014 )
Map it to a shortcut ( i have mine on Num-0/insert which is bigger than normal keys) and type the toolname .
The shortcut should be listed along with the exact toolname
