Autodesk 3ds Max 2014 Service Pack 2 is now live! http://autodesk.com/3dsmax-updates and http://autodesk.com
This includes the XP x64 startup fix.
Excellent, though I'm more interested in the Nitrous UV fix than XP.
I understand that XP support can be important for render farms, etc. But I do have to ask this Steve: why XP still? Is there any specific reason you are still using XP or is it just that your machine just happens to serve you well. I recently helped someone using XP and realized it had been years since I used it and it demonstrated (to me) how much nicer Win7 is... (in my opinion).
this is a pretty weak update. Yay for users still using XP on old machines. I probably won't even install it. It's not worth my time. I'll wait till they at Least fix the huge mirror bug.
You guys always seem to only post up the Max without including the design link. And they release 2 different service packs which don't work on the wrong version.
So here's the 3dsmax design link for those that might want it. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22026236&linkID=10381720
Not only did this update enable using the SP1 stuff with my XPx64 render farm (thus preserving a perfectly functioning pipeline without spending 4K+ on system rebuilds), but it also fixed issues I was having with MAX2014 on Win7!
Thanks AD! Greatly appreciated.
I understand why people have been complaining that it's only two fixes, but to look at it from a positive point of view, this is not long after SP1, and it is something that people were quite vocal about. So, autodesk listened, and got the SP out quickly. That is a good thing.
But it would be nice if they could fix the errors with the iray material between Autodesk and Nvidia. Hint hint.
after installing SP2 the problem that was there after installing SP1 started again for me and it is whenever you freeze the object and uncheck the option in the properties bar "show frozen in grey" it still turns the object grey. why so ??? please help if any solutions are there
I just relized...
We abandoned the PU in favor of the SP...
Something is stinky around here...?
Is it just me, or has AD somehow managed to fundamentally break max 2014 with these SPs? I just somehow managed to finish a job, and it took easily three times as long as it should have - there's a scaling problem with XREFs, where a job with an XREF rendered in backburner changes the scale, the same problem causes a saved file with an XREF to come in at either a different scale or position (both reported and logged), there's shadow bugs, something causing renders to take 10X longer than they should, and overall max is doing an FE with a disturbing regularity - my best this week was 30 FEs in one single hour.
I complained, and AD actually offered my money back for subscription. Though, that doesn't actually do me any favors, since they'll then take my subscription away. (Taking away my ability to report bugs doesn't seem productive).
I'm going back to 2013, for the time being. Still garbage, but vastly better than 2014, save for the nitrous speed. (Completely lost for the time reloading...)
Hi, my administrator just installed SP1 and SP2 for 3dsMax2014, and now I'm getting this message when starting up MAX.
(State Sets didn't work before, but I didn't got this message)
Max 2014
Bootcamp on IMac, Windows7 Pro
and this one when opening State Sets:
Then as well when opening a scene I get the Missing Dll AnchorHelper Superclass:0x1160,
I'm on a movie and things are really turning bad,
I need a solution for these problems, so any help welcome
Dominique Gantois
PrimaLinea Productions Angouleme, France
I would strongly suggest that you get the SPs removed.
I removed them on my machine, and have had vastly less issues with 2014. Xrefs are still broken, but I can at least get some work done.
Kris.
Thanks Kris,
but that doesn't change the State Sets Problem,
without the SPs, I had an empty StateSets Window, no Icons, no Buttons, ...the dessert,
a solution should come from Autodesk,
Dominique (going BBad!)
