Hi There,
I just wonder if anyone knows how can i array the pink extrudes along the path ellipseevenly . I tired the snapshot and animation combination and also the align> spaceing tool command but the outcomes are not as I expected. Is there anyone knows the solution for this.
Cheers
The outcome from using spacing tool will not be ab le to align all the extrudes towards a center (please see the picture as below). Cheers
Are you trying to create a cage like effect? Did you try the Array tool? It should work - set the pivot point of pink objects to the center of the cirles and set how many you want.
Using circular array only work for perfect circles. I tried spacing tool as you can see the image below. Would that be the reason of some settings such as the pivot location?
The second question is what is the best way to self learn 3d Max? I can see there are many courses and videos out there but I would like to find out the most effieient one. Frustration is skill my motivation sometimes that leadts to irrationality lol.
Millions of thanks
Ivan
It really helps. I am really interested to know how the placement of objects in positions and angles affect the array outcomes. I also experimented the follow selection does not do what i expected but i not sure how to explain it. Please see attach images.
