Hello!
I have created a 3DS max scene. I have Rendered the scene and it outputted to Targa image files of all the frames. The size of the frames are 1920x1080. I opened up the 3DS max RAM player and loaded all the images into the player. It is able to play them in sequence at 30 Frames per second at a size of 1920x1080. However, when I save channel A as an AVI file, it shinks the size of the frames down to 720x480 in the video. Why is this happening? And how can i fix it? I would like to export a video that is 1920x1080.
Solved by iadproductions. Go to Solution.
Ahogue,
You are experiencing this problem becuase you are choosing the DV codec for the AVI format which is limited to 72x480 resolution.
What is your deliverable, does it have to be an AVI file? Is it Blu-ray or web video?
Try exporting out to a Quictime MOV file using the H.264 codec.
Jeff
Hi sir, you seem to know MOV a lot, I also have a problem with MOV. I have a large 10-minute MOV video that I wish to send to a friend through email, but the file is too large for most email clients. I found Quora has the same question https://www.quora.com/Whats-the-best-way-to-compress-a-mov-video I downloaded the program( http://www.videoconverterfactory.com/tips/compress-mov-file.html) because there are many people recommend it, actually, I don't know these parameters, so I seemed did something wrong....I am not sure but the program showed error! anyone use this program? Appreciate any help!
