Extension 2 (which include SP3) is ready for download...
As usal: I get no mail about it 😞 -> Vote: http://3dsmaxfeedback.autodesk.com/forums/76763-small-feature-requests/suggestions/2238474-mail-3dsm...
EDIT: Very slow to install, isn't it? Vote -> http://3dsmaxfeedback.autodesk.com/forums/80695-general-feature-requests/suggestions/3137313-optimiz...
btw. does Ext 2 include Ext 1 ???
Are service packs still cumulative?
It doesn't make note of it in the notes for SP2 or 3.
IMHO SP are always cumulative...
The question is, what's with ext2 ? Ist ext1 included?
Can somebody explain how to use sequencer ?
My problem :
I have a camera A, animated from frame 100 to frame 200.
I create a state, activate camera track, move begin and end track to 100 and 200
If I move camera A's track in sequencer, so the track goes from frame 0 to frame 100, my camera is not animated from frame 0 to frame 100.
Help please...
Another question: Why is the new backburner v2015.0.2 build 1699 not included in SP 3?
Seperate backburner update is here: http://knowledge.autodesk.com/support/3ds-max/downloads/caas/downloads/content/backburner-2015-windo...
And, there is no README about changes 😞 Hopefully it fixes bug and doesn't contain more bug
XRef Scene are always invisible after exit a isolation...
Can someone confirm?
Is there a reason why we can only install SP3 through the application manager instead of simply downloading it from the website?
This means we need to download this SP3 on every computer to install in individualy on every computer on our renderfarm... really?...
Just download it here: http://knowledge.autodesk.com/support/3ds-max/downloads#?rows=10&sort=PublishDate&p=3ds%20Max&cg=Dow...
No?!?
direct link: http://knowledge.autodesk.com/sites/default/files/file_downloads/3dsMax2015_SP3.exe
Steve, SP3 isn't in the 'Featured' list above, but if you look at the list below you'll find the link. Also helps to filter by 2015 on the left.
Chris Medeck
Hello ,
Current info on this > Extension 2 is cumulative so should have previous service packs in it.
For "XRef Scene are always invisible after exit a isolation..."
I could not reproduce that with simple scene consisting of some planes and sphere.
This post has multiple submissions > if you all are getting specific reproducible issues please do start entering
them in link below so they can be routed to relevant people / departments for testing and investigation.
www.autodesk.com/3dsmax-defectsubmission
Best Regards
VR
Hello again,
Sorry if this got posted twice, seems to have not worked first attempt.
Wanted to be sure you got the info .
them here so they can be routed to relevant people / departments for testing:
Best Regards
VR
This happens not all the time. I didn't find the steps to reproduce it... I will continue to monitor this.
Where can i download extension 1 and 2 for max 2015.. Please share a link because aparently i am retarded and i cant find it.
