In 3dsMax 2014 I have noticed that when you select an object it will display it's wireframe. You use to be able to cycle through the F3 and F4 combinations to show/hide this wireframe however it does not appear to work in 3dsMax 2014.
Is there another way (besides the F3 + F4 hotkeys) to disable this wireframe on the selected object?
My attachment should hopefully give a better understanding of the problem.
Solved by PROH. Go to Solution.
Perfect, cheers!
