3DS Max Icons Missing, Lots of UI Elements White
Message 1 of 19
here is what my interface currently looks like when i Open Max, I have been trying to fix this for 4 hours now with no results and have done the following;
Uninstalled and Reinstalled Max
Repaired Max
Updated Drivers
Loaded the default UI back in
Turned computer off and on again
Tried to deal with it
I honestly don't know where to go from here and it is heavily detrimental to my work right now as well as being extremely frustrating so any help is greatly appreciated as I cannot work properly until this is fixed
Also now when i go to select polys it will only select them if my select box goes over the entire poly rather than just touching it,
Replies (18)
Message 2 of 19
Daf
I know that's gotta be frustrating! 😞   What are your computer specs?
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
Message 3 of 19
Processor Brand Intel
Processor Type Core i7
Processor Speed 3.2 GHz
Processor Count 4
RAM Size 8 GB
Hard Drive Size 1 TB
AMD Radeon HD7650M
Graphics Card Ram 2048 MB
Message 4 of 19
Bump
Message 5 of 19
Autodesk has a list of supported hardware for all their applications including 3dsmax. You can google it. Are your video drivers up to date? Have you googled to see if other people have similar problems with the card you are using? I know I am having interface problems with max 2015 but my video card is pretty old so that is my problem not the software.
This doesnt help you but what might is reverting from nitrous to direct 3d via customize/preferences/viewports choose driver and the legacy direct 3d. Its not as pretty but it will get you up and running while you trouble shoot your video setup in ref to max.
Cheers
Message 6 of 19
I said in my first post what I have tried already and this problem has not been permenant it just occurred recently, I'll try the second thing you said though
Message 7 of 19
Yeah, is your vid card supported? You actually need someone with the same card and problem who has found a solution. Sorry I am not that person.
Message 8 of 19
CAMedeck
I've run into some weird UI problems, and it is usually traced back to some corrupt files in your user folder.  Here's something worth trying...
Go to C:/Users/USERNAME/AppData/Local/Autodesk/3dsMaxDesign/(version)/
Here you should find a folder called ENU.  Rename it, like ENU-OLD.  Then start Max and see if that fixes anything.  If it does, then you know something in there is broken.  Many of the files in the OLD folder can be copied back, but keep track of what you move so you know which one is the culprit.
Chris Medeck
Message 9 of 19
Thanks so much man that did the trick, really appreciate it and thanks to everyone else who gave input too 🙂
Message 10 of 19
jamesabell_2000
Observer
Observer
Hello please help,
I have the same problem. I have Windows 7 Premium. It worked before just suddenly did exactly the same thing the other day.
I really need to use it with the icons for screencasts I am making.
The problem in the folder, I cannot find this folder -
'Go to C:/Users/USERNAME/AppData/Local/Autodesk/3dsMaxDesign/(version)/'
This is not there, when I go to USERS/USERNAME/ there is no 'appdata' folder.
See attachment, please help me! Is it in another area?
I also installed/reinstalled 3ds Max and it still has this problem.
Message 11 of 19
jamesabell_2000
Observer
Observer
I actually found a file in 'roaming' it still does not solve the issue. It is terrible, it was working a few days ago. I will see if perhaps windows updates if any were made may have done this. This is crazy.
Message 12 of 19
Steve_Curley
Because Appdata is a hidden folder. Set Explorer to "show hidden files and folders" and you'll find it and the ENU folder. Do NOT modify anything in Roaming, those are not the files/folders you need to rename or remove.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 13 of 19
jamesabell_2000
Observer
Observer
Thank you! Thank you! Thank you! 🙂
Message 14 of 19
thank you sir that helped me alot
Message 15 of 19
Repaired Max
Updated Drivers
Message 16 of 19
Try and switch drivers in max. Perhaps you are on nitro and your rig cant handle it. The drivers in max are in the preferences/viewport. You will have to restart max.
Message 17 of 19
I had the thame error, while testing first release of max 2017. Looks like it's not fixed yet, even in sp2?
What can I say, it's not surprising.
Message 18 of 19
I tried out what you said. I renamed the folder to ENU-old and restartet max. A new folder appeard named ENU. But max lost all the pathes to textures etc.
The solution to this was to copy the UI folder from en-US inside the new ENU folder that appeard and copy paste it into the ENU-old one.
I then deleted the new folder and renamed ENU-old to ENU again. It works like a charm 🙂
Ty!
Message 19 of 19
I was having the same issue, I have no idea why this fixes it, but grateful none the less
-Thanks!
