3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
3D view cut off problem
3 REPLIES 3
finnegandevuyst
1554 Views, 3 Replies
Hi guys
Since today Im having a problem with a new project I started. I imported a 3D studio file from Archicad to 3dsmax Design 2015.
Problem: Whenever I wana see inside the building, in perspective of with a camera the sides of the building are being cut off for some reason. I can't see what I will render because of this and I can barely select anything in a 3D view.
The problem does not ocure in other files
Does anyone know a solutions for this?
Specs: Macbook pro retina 15, Bootcamp Win 8.1
Any tips are welcome 🙂
Finn
Tags (1)
3 REPLIES 3
Could be a lot of things, but  i remember having the same problem, and my solution was to delete this cam and create a new one.
Can you try this?
nah1992
in reply to: eric.paris
does any one have any other suggestions regarding this question?
miledrizk
in reply to: finnegandevuyst
I think your system unit is big and your imported model is very small,
For example, if your system unit (not to be confused with the display unit) is in Meters,
And your model is made using a 1 unit = 1 mm then you can expect something like this.
Now if you don't want to start all over, then what you can do is click on the Viewport's name
then choose Viewport Clipping, two yellow rectangles will appear on the right side,
Drag the upper one all the way up and the lower one all the way down
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
