Area :: Header
Sweat, Swearing & Tears
Cupcakes & Critters reflects on what it takes to bring an indie game to market. Watch now
3ds Max / 3ds Max Design General
New Member
0 Kudos
3D PDF
363 Views, 11 Replies
03-01-2014 10:16 AM
Hi
how to create 3d pdf with autoesk matrial
Moderator
74 Kudos
Re: 3D PDF
03-03-2014 08:08 AM in reply to: santosh2212
I'm not sure if I understand the question. Could you explain what you are trying to achieve?
E. K. Anna Hennequet
Moderator
44 Kudos
Re: 3D PDF
03-03-2014 08:43 AM in reply to: santosh2212
Good question. I'm not sure that there are any apps that stand alone for this from ADSK and I'm sure that Max can't do it directly.
Paul Neale
PEN Productions
http://penproductions.ca
Win 7 64bit
Nvidia GeForce 760
8 Kudos
Re: 3D PDF
03-03-2014 02:22 PM in reply to: santosh2212
I had a similar issue recently. I ended up buying a plugin called Tetra4. Complete waste of money. The 3D PDFs were huge and the quality was very poor. I compared the scene exported from MicroStation to 3D PDF. The 3D PDF exported from MicroStation was 8mb. The same scene exported from Max using Tetra4D was 110mb.
I eventually abandoned the idea of 3D PDF and talked my client into an animation. One other option is a series of panaramic images. You can put them into a product called Pano2VR. You can link the panoramic images by placing hot spots into the pano2vr. You won't have a 3D PDF but you can create a HTML 5, quicktime or flash ouput. The advantage of this is you will have a very good quality product because your rendering out og Max using yor render engine of choice.
If anybody has found a good quality 3D PDF solution it would be good to know. For now from my experience even though its possible but its not a viable solution
New Member
0 Kudos
Re: 3D PDF
03-03-2014 05:39 PM in reply to: donied
You can try the SimLab PDF Exporter for 3ds Max. You can publish the materials and there is a setting for the bitmap resolution; the files don't get too big as well.
Distinguished Contributor
4 Kudos
Re: 3D PDF
03-19-2014 02:45 PM in reply to: 3DTani
Simlab is not able to export animations. Is there any other solution than this?
Distinguished Mentor
120 Kudos
Re: 3D PDF
03-19-2014 04:12 PM in reply to: istan
Hi. Are you sure the 3D PDF format does support animations? I've never seen that, nor heard about it, but maybe I'm wrong?
24 Kudos
Re: 3D PDF
03-20-2014 02:00 PM in reply to: santosh2212
SAP visual enterprise can output 3D PDF's. I can also do it with Adobe Acrobat 9 Pro Exteneded.
Dean
Max 2014 (SP2)
Win 7 64-bit; Dual Xeon E5-2687W @ 3.10 GHz; 64 GB Ram
NVIDIA GeForce GTX 570; Quadro 4000
4 Kudos
Re: 3D PDF
03-20-2014 02:47 PM in reply to: PROH
See e.g.: https://www.youtube.com/watch?v=oHpZE0zTHZU
But it does not work with 3dsmax..
4 Kudos
Re: 3D PDF
03-20-2014 02:49 PM in reply to: Pyro777
But no animations, or?
