Hello everyone.
I came across to a problem that I'm trying to sort it out for the last 2-3 days. I installed 3D max 2012 on my laptop and 2013 also but I'm not able to install the 2014 version. I did uninstall everything, deleted all roots and folders and everything and when I'm trying to install 2014 version is coming up as 3D max Composite 2014 already installed and all I can install is the library and all other options.
Now, I did try to find the 2014 but I can't find it anywhere on my laptop. Does anyone has an opinion or a suggestion on this issue? I need 2012 in my laptop as I have some plugins that I still use. I'm happy to listen some suggestions in order to sort out this problem.
Thank you everyone in advance for your time and help.
Best regards,
Octavian
Have you tried something like CCleaner to clean out the registry? I ran into the same kind of problem recently with another software. I had removed folders and every incidence I could find for the program, rebooted and tried to reinstall. It kept saying, "already installed. " I ran CCleaner and it found some stray residual keys. I removed them and tried again. The program installed.
Not sure it will solve your issue but it might.
Rob Holmes
