Please post any links that will help , 3d max 2010 will this work with windows 7?. Program 3D Max will open but all shaders are missing Including Metaballs .
3ds Max 2010 was officially tested and certified for Windows XP and Vista, not Windows 7 or 8.
This link contains info on current and past versions and what Operating Systems they are supported on.
You should always stick to the Operating Systems that specific versions of 3ds Max have been certified on,
for full functionality and stable performance.
However if you want to try and run an older version on a newer unsupported OS, maybe verify you also have
latest updates for 2010.
No guarantees it will work but worth a try, installing latest service pack as per above.
Best Regards
VR
oops forgot another tip, maybe disable any Windows Aero and fancy desktop transparencies.
The older versions of 3ds Max used to have issues with those newer options in Windows.
Also disable User Account Control in Windows.
Thanks so much for Info,. I will have to upgrade or reactive 3D Max 9, I thank I will upgrade makes sence , Thanks Curt.
