Why am I not surprised?
I have Administrator group policy. Right-click 'Run as administrator...' used.
Version=1 EventType=PCA2 EventTime=130542269838749051 Consent=1 UploadTime=130542269838749051 ReportIdentifier=f39348da-3373-11e4-a05b-4437e678cbc0 Response.BucketTable=5 Response.type=4 Sig[0].Name=Problem Signature 01 Sig[0].Value=setup.exe Sig[1].Name=Problem Signature 02 Sig[1].Value=0.0.0.0 Sig[2].Name=Problem Signature 03 Sig[2].Value=setup.exe Sig[3].Name=Problem Signature 04 Sig[3].Value=unknown Sig[4].Name=Problem Signature 05 Sig[4].Value=unknown Sig[5].Name=Problem Signature 06 Sig[5].Value=1 Sig[6].Name=Problem Signature 07 Sig[6].Value=201 DynamicSig[1].Name=OS Version DynamicSig[1].Value=6.1.7601.2.1.0.256.48 DynamicSig[2].Name=Locale ID DynamicSig[2].Value=6153 State[0].Key=Transport.DoneStage1 State[0].Value=1 FriendlyEventName=Program compatibility problem ConsentKey=PCA2 AppName=setup.exe AppPath=C:\Users\dgrehan\Downloads\3dsMaxDesign2015_SP2\setup.exe ReportDescription=This program might not have installed correctly
Mentions 'Program compatibility problem'.
I have downloaded the 2015 Max Design specific file.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Is there an additional installation log that you can check for potential clues?
Hi and thanks for the tip. I created a logging string with regedit and retried the installation. When it failed it made an MSI*.log in %Temp%. It's 18,760kb.
So I copied some important bits out for you:
Property(S): ServicePackLevel = 1 Property(S): MsiRunningElevated = 1 Property(S): ACADLICENSETYPE = Stand-Alone License Property(S): PATCH = C:\Users\dgrehan\AppData\Local\Temp\RarSFX0\3dsMaxDesign2015_SP2.msp Property(S): WindowsBuild = 7601 Property(S): ShellAdvtSupport = 1 Property(S): VersionDatabase = 405 Property(S): SRCTEST = C:\Users\dgrehan\AppData\Local\Temp\RarSFX0\3dsMaxDesign2015_SP2.msp MSI (s) (C8:A4) [11:00:35:742]: Product: Autodesk 3ds Max Design 2015 - Update 'Autodesk 3ds Max Design 2015 SP2' could not be installed. Error code 1603. Additional information is available in the log file C:\Users\dgrehan\AppData\Local\Temp\MSIf78e6.LOG. MSI (s) (C8:A4) [11:00:35:742]: Windows Installer installed an update. Product Name: Autodesk 3ds Max Design 2015. Product Version: 17.2.259.0. Product Language: 1033. Manufacturer: Autodesk. Update Name: Autodesk 3ds Max Design 2015 SP2. Installation success or error status: 1603. MSI (s) (C8:A4) [11:00:35:743]: Note: 1: 1729 MSI (s) (C8:A4) [11:00:35:743]: Note: 1: 2205 2: 3: Error MSI (s) (C8:A4) [11:00:35:743]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1729 MSI (s) (C8:A4) [11:00:35:743]: Note: 1: 2205 2: 3: Error MSI (s) (C8:A4) [11:00:35:743]: Note: 1: 2228 2: 3: Error 4: SELECT `Message` FROM `Error` WHERE `Error` = 1709 MSI (s) (C8:A4) [11:00:35:743]: Product: Autodesk 3ds Max Design 2015 -- Configuration failed. MSI (s) (C8:A4) [11:00:35:743]: Windows Installer reconfigured the product. Product Name: Autodesk 3ds Max Design 2015. Product Version: 17.2.259.0. Product Language: 1033. Manufacturer: Autodesk. Reconfiguration success or error status: 1603.
http://support.microsoft.com/kb/834484 (Error 1603).
This seems to be along the similar lines as previous users errors when installing SP1, myself included.
Darawork
AutoDesk User
