2014/08/21 14:27:45 INF <AdapterInfo>
2014/08/21 14:27:45 INF <Name>Autodesk 3ds Max 2015 (64-bit)</Name>
2014/08/21 14:27:45 INF <Version>300</Version>
2014/08/21 14:27:45 INF <Description>Autodesk 3ds Max 2015 (64-bit) Renderer Adapter</Description>
2014/08/21 14:27:45 INF </AdapterInfo>
2014/08/21 14:27:46 INF <AdapterInfo>
2014/08/21 14:27:46 INF <Name>Command Line Tool</Name>
2014/08/21 14:27:46 INF <Version>300</Version>
2014/08/21 14:27:46 INF <Description>Command Job Adapter v2015.0.1</Description>
2014/08/21 14:27:46 INF </AdapterInfo>
2014/08/21 14:27:46 INF Starting backburner Server
2014/08/21 14:27:46 INF Loading plugin: Autodesk 3ds Max 2015 (64-bit) Renderer Adapter from Backburner Adapter Plugin
2014/08/21 14:27:46 INF Loading plugin: Command Job Adapter v2015.0.1 from Backburner Adapter Plugin
2014/08/21 14:28:08 INF Registration to 132.234.25.195 accepted
2014/08/21 14:28:35 INF Receiving new job from 132.234.25.195
2014/08/21 14:28:36 INF Job 'Earth_005' received and ready
2014/08/21 14:28:36 INF Launching 'Autodesk 3ds Max 2015 (64-bit)'
2014/08/21 14:28:54 INF 3dsmax adapter : Executing command line : C:\Program Files\Autodesk\3ds Max 2015\3dsmax.exe "-_pipe:82370531" -server "C:\Users\s2123765\AppData\Local\backburner\ServerJob\Earth_005.max".
2014/08/21 14:28:54 INF [ServerMessage]ProcessStarted processId=9192
2014/08/21 14:28:54 INF 3dsmax adapter : Autodesk 3dsMax 17.1 is Ready.
2014/08/21 14:28:54 INF New task assigned: 0
2014/08/21 14:28:56 INF Adapter returned unexpected code -2 for "C:\Program Files\Autodesk\3ds Max 2015\maxadapter.adp.exe" "-o" "NewTask" "-l" "Info" "-j" "C:\Users\s2123765\AppData\Local\backburner\ServerJob\Earth_005.xml.details" "-s" "0" "-n" "1" "-a" "C:\Users\s2123765\AppData\Local\backburner\ServerJob\Earth_005.zip" "-d" "utf-8"
2014/08/21 14:28:56 ERR Task error: 3dsmax adapter error : Autodesk 3dsMax 17.1 reported error: Could not find the specified file in DefaultSettingsParser::parse() ; Could not find the specified file in DefaultSettingsParser::parse() ; Could not find the specified file in DefaultSettingsParser::parse() ; Could not find the specified file in DefaultS
2014/08/21 14:28:56 ERR 3dsmax adapter error : Autodesk 3dsMax 17.1 reported error: Could not find the specified file in DefaultSettingsParser::parse() ; Could not find the specified file in DefaultSettingsParser::parse() ; Could not find the specified file in De
2014/08/21 14:28:56 INF Application is down
2014/08/21 14:29:05 INF 3dsmax adapter : Autodesk 3dsMax 17.1 shutdown.
