Hi everyone !
First of all, I'm french so I appologize for my bad english 😉
My problem is that since I reinstalled Windows 7, everytime I start my 3dsMax, it appears the following message :
Then, max doesn't finish its launch.
I have max 2014 but it's the same with the 2013 version.
It worked very well before I reinstall Windows. I have this problem for about 1 week and I'm clueless now T_T
Could you help me resolve this please ?? I really need this software for my studies...
Thanks.
Antoine
P.S. : My computer
- MSI GE70 Laptop
- Intel Core i7
- 8GO Ram
- GeForce GTX 660M
- Windows 7 64b
Solved by Alfred.DeFlaminis. Go to Solution.
Hi Jessica !
My problem is solved now, just doing a scan of the registery with CCleaner 😉
Try it ^^
When you reinstalled Windows did you also reinstall ALL the service updates? It will take a very long time to catch up to all the "updates."
For anyone who is still having this issue
This might be the solution as it helped me to solve my Max launch problem:
If this will not work, try any other solutions from here:
I hope this helps.
Have a nice day or night.
Hello @adomas.storpirstis and welcome to the community,
I'd like to commend you on your community minded nature here, that's really nice of you to post this in here with the goal to help others. If I could give you a mega-kudo I would do so. This thread does predate 2018 by a few years but I really like your attitude and I wanted to thank you for being such a team player! You are appreciated. In the off chance that others find this thread with problems in 2018 and starting up, please see this article.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Terminate the programs that are :
*Involved in the registry manipulations.
*Keeping logs of your system (viruses included)
*Run as a background process controllers, any software that is keeping your system "clean", Iam using bugged to hell custom made software that is terminating any side processes immediately, with manual conformation of any processes launched.
I had this error on one PC for about two days, and it drove me crazy.
I was rigging some model, when max offed himself with critical error, then I could not launch max for said two days.
Turns out, this soft I was using to keep track of processes and system load, "saved" 3ds max process in the same state it was when the error occurred, and each time I was trying to launch it, it went off with this error on the loop.
I went NUTS, manually going through everything trying to understand what caused this.
Turns out, no matter how sure you are in third party software, it always helps to consider all options, by turning it the hell off.
Hi Antoine!
My English isn’t good as well.
i’m dealing with the same problem as you.
i found many ways to resolve it. but i haven’t dealt with it yet.
If you done it.
Coud you help me resovle this please?
Many thanks!
