3ds Max Animation and Rigging
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max animation topics.
How to remove a cat rig from a model
9 REPLIES 9
Message 1 of 10
3791 Views, 9 Replies
I am trying to remove a cat rig from a model but I am finding that I can not delete out the big tri angle base plate. When I try to delete the cat base plate it also deletes my model mesh from the scene. I have been able to delete all the cat bones with no problem. Is there something I need to do special to get CAT completely removed from my model file?
Thank you in advance on any help on this issue.
9 REPLIES 9
Message 2 of 10
samab
Unlink any model parts that are linked to the rig and remove the model's Skin mod.
Message 3 of 10
Samab,
That is what I thought it was as well so I triple checked and All links and skin modes are removed and still no go. Thank you for the suggestion. Ahh CAT!!!
Message 4 of 10
tyree_10
use mesher to make a copy of the model
Message 5 of 10
Tyree,
Could you give a step by step on how I would use mesher to remove the cat base plate? Only thing I am finding on mesher is to convert particles to a mesh. Using this mesher will it effect the hero model in anyway? such as uv mapping?
Message 6 of 10
tyree_10
you could also duplicate the model and remove the skin modifier. the mesher model wouldnt have uv coordinates, but if you already have the map done. the mesher model wouldnt need a uv. just apply the map from the original to the mesher model
Message 7 of 10
I was hopeing that maybe I was just missing something simple to remove a cat rig base plate. Thanks for the suggestion Tyree but that just seems to be just a little to much to do to just remove the base plate. No worries I will just install my new none cat rig in my back up model that has never had a rig installed in it. I am sure glade over these years I keep a clean model file.
Best of luck to you all.
Message 8 of 10
Hi...
01. Remove catmotion layer from motion panel, just right click & remove.
02. remove skin modifier
03. Then Remove cat rig.
I hope it will work for u..
Message 9 of 10
Hi…
01. Remove catmotion layer from motion panel, just click on delete layer button.
Stop catmotion layer first.
Message 10 of 10
Graeck
You have to remove all parts of your character (mesh) from the Extra Parts list of your CAT rig. Select the CATParent, go to Modify Panel, press "Add Rigging", and remove all items from the list. After that, you will be able to delete your CAT rig without your mesh being deleted. Reason for this is as long as your mesh is part of the Extra Parts list and so part of the CAT rig, it will save and load with the CAT RG3 format.
My CAT demoreel:
http://www.youtube.com/watch?v=Gfq-4VoeAPU
