3ds Max CAT rigging / Video tuts 🙂
Hope these help. They are a bit older (2009 and older)
All videos are in this zip file;
https://drive.google.com/file/d/1isyHGsXBXLgKshpqAhr8m9bKFQ9m5gaq/view?usp=sharing
link for the CAT rigs;
https://drive.google.com/file/d/1BfJvxiviry-WMA8CptgVKjERMqG_Z0cr/view?usp=sharing
From my Google Drive, if you hit any issues, please feel free to let me know, I'll be glad to help:
joshpurple@gmail.com
For learning CAT rigs and animation, Milos Cerny is a great resource! Thank You Milos!
https://www.youtube.com/@MilosCernyAnimation
Solved by joshpurple. Go to Solution.
Thanks for all these Josh, you really are helping out a lot of people.
When doing the Joe Gunn Rotations Tutorial, did you encounter the problem of the rotation reversing itself half way along the path?
If so have you figured out a solution?
I noticed that it also happens in the tutorial movie, you can just catch a glimpse of it when he reverses the direction of rotation at the end of the path.
Thanks again for all your input on this board.
Creating Custom Gizmo Hierarchies
It is not necessary to link Gizmo objects to any part of the CATRig, although if you wish, this is not a problem. Often it is more interesting to link the gizmos together.
You can create hierarchies of Gizmos that reflect your desired navigation of the rig, rather than the actual hierarchies of the CATRig. You can link the ribcage gizmo directly to the Pelvis Gizmo and then quickly navigate your rig using the PageUp and PageDown buttons.
Defying the laws of Circular Dependencies
You are able to Link Gizmos together in ways that would normally cause a circular dependency in Max. You can, for example, link the Gizmo for the FootPlatform directly to the Gizmo for the Ankle without causing a circular dependency.
Hey man i can´t download all the rigs you have been posting?....can you help me? {:¬)
