3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
.stp import stick thingies
4 REPLIES 4
Streetwise
513 Views, 4 Replies
I was recently given a .stp file and imported it into 3ds 2013. I think it will work, but I have two questions:
1) What are all the pick-up stick things for and how do I turn them off?
2) A couple of the product parts look like they did not come in properly
3) Is there a better way to import .stp files, or perhaps a translator of some sort?
Thank You.
Tags (2)
4 REPLIES 4
istan
in reply to: Streetwise
a) could you probably upload the file?
b) if i experience importing troubles, i use inventor to import the step file. then i import directly from inventor to 3dsmax.
c) check the npower step importer. this is the best step importer i currently know
Streetwise
in reply to: istan
Here you go.  Turns out they are "Point Helpers". I can select them and delete them.
I tried opening it in Inventor Fusion and all I see is a cam lock. Weird.
Streetwise
UPDATE:  I opened the step in Inventor professional and then exported to Inventor. I then imported the Inventor file(s) back into 3ds, and it looks terrific!  Thanks for your help.
istan
I have no idea, what you did, but here it imports with inventor as expected..imp.png
