hi guys (sorry for my english )
i have 3 problems in 3d max 2015
1- the graphic of model texture's is very very low (in viewport)
2- the model's graphic is very low too (in viewport) . the line of model is not soft and ...
3- zoom with middle mose is very fast and when i want to zoom to my model .camera move the other side of my model
this is image of my problem
http://s5.picofile.com/file/8131721550/Snapshot_2014_07_17_085311.png
RE: Viewport background image problem.
There is a script file that you can run after you boot into Max, set nitrous texture is the name of the script file. This will fix your image background problem. You can find it on the forum's search engine or you can go to Autodesk and search for it. Just follow the instructions and your background image will not have a lot of jagged edges. As for your model, it shouldn't have any pixelated lines. If this condition continues, then I would complain loudly to your Autodesk rep. Ask the rep. why they have a new driver that doesn't allow the user to re-set the driver manually. My nitrous driver is greyed out and you cannot access it. (I'm running ver. 2014) Haven't used 2015 yet. Good Luck!!
SM
Everything to fix your problems can be found in Viewport Configuration->Display Performance.
Pretty much self explanatory, i think.
