Hello Guys,
I have been plagued with problems with the new 3ds Max 2014.
My XYZ coordinates are completely empty. this is both when hovering around and transforming objects. I am using 3ds Max 2014.
I hvae read that to toggle this back on i should press (X) or (CTRL SHIFT X)
However,
X brings up "search all actions" and "CTRL + Shift + X" doesn't do anything?
Also,
My shift and drag does not copy any geometry
and Click + Shift + select does not loop select ?
Can anyone help please?
Solved by darawork. Go to Solution.
See screengrab below. That X,Y,Z display?
That is always blank, until you select an object, then it turns into the transform type-in (Absolute or Offset modes).
It's not the same as a co-ordinate read-out area, e.g. AutoCad or similar.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Thank you for this.
Where are the XYZ coordinates located then? As i am watching online tutor's via Digital Tutors and the tutorial has XYZ coordinates in those boxes when he
hovers around the viewport?
Seems to be a documented bug alright: http://forums.autodesk.com/t5/3ds-Max-3ds-Max-Design-General/Displaying-Coordinates-When-Moving-Mous...
Not sure if it was fixed since that post, doesn't seem like it was.
Darawork
AutoDesk User
Ahhhh thanks for this hopefully it sorted in the next service pack 🙂
Could you shed any light on any of my other problems?
I don't know if Max ever had shift loop selection cycling, like the process in AutoCad? Did it?
As for shift dragging not creating copies/instrances/referances.... That's a wierd one alright.
You have the move tool selected first yeah? The shift key is actually working..? Normally, outside of Max?
Darawork
AutoDesk User
Do you have Interaction mode changed to Maya?
Customise menu -> Preferences -> Interaction Mode tab.
Maya mode turns off the ability to [SHIFT] clone.
Darawork
AutoDesk User
In relation to the loop selection i am referencing to this.
http://www.youtube.com/watch?v=oZq22dd7Ex4
and yes my shift buttion works just fine and yes i am in my move tool it just doesn't want to play ball :s?
It's not the end of the world because of course i can just press CTRL +V and create my copies and then move them.
But it would nice if they worked lol
Youtube is blocked here, grrr.
Did you check for Maya mode?
Darawork
AutoDesk User
How would i do that sorry?
No problem:
Darawork
AutoDesk User
Thank you kind sir !
That has solved my problem on that front.
This is a fairly new install so it actually wasn't set to either.
Now it works as it should except for the coordinates.
Thanks a bunch for your help
No problem, I was looking for a 3rd party plug-in that would display the coords but found nothing. 😕
Darawork
AutoDesk User
Arrr what a shame (n)
Thank you for all your help it has been very much appreciated.
Just noticed that the Coordinate system is working again in 2015 🙂
Darawork
AutoDesk User
