I had a functioning 2013 3ds Max installation until I tried to install the extension for the program. After working for several hours I could not get the program to install, so I decided that I would uninstall everything Autodesk and begin anew. I spent a huge amount of time trying to remove everything and still I couldn’t remove the main program. I have a “search everywhere” program that helped me locate some files that did not get removed using Windows Control Panel Programs/Features. I removed these files, as well as anything “Autodesk” in the registry. I also removed anything in the AppData in several places and in the temp file in Windows. As you can imagine, by this point I have spent several days and many hours getting more frustrated by the hour. I would re-boot the computer and try to re-install the 2013 version, but to no avail. The only things that installed were: BackBurner, Direct Connect, Inventor Server Engine for 3ds Max, Revit Interoperability, and the essential Movies For 3ds Max. I tried the Setup in the expanded downloaded Autodesk_3ds_Max_2013_EFGKJS_Win_64bit file and the window that opened indicated that the program was installed. However, it is nowhere to be found. During all of this, I have re-downloaded the files several times just in case there was an issue with the downloads.
I even tried to revert to the 2012 version to see if it would install successfully, but again no luck! How could I have had a working program and now can even get the program to install in either version? I have searched in the forums and Autodesk help and found nothing that addresses my problem. Maybe someone “out there” has had some similar experience and can offer some help to this very tired and really frustrated human being.
I thank anyone in advance for trying to provide help,
Tom
