Hopefully this has an easy answer. I am working in Revit with millimetres units. When I import the model to Max and apply Autodesk materials, the material scale is all out of whack!! Can someone please tell me what the Units setup in Max should be for importing Revit models in millimetres ? What should the Display unit scale be set to ? What should the Sytem Unit setup be ? Thanks for your help in advance.
Here is the same.
Our architectural office bought more than 20 licenses Biulding Ultimate, constantly work between revit and 3d max, the problem you mention is the reason, why, we delay in setting up the scene renders to make and sell to our customers.
As it is possible that something as basic as conxion between Revit and 3d max, is so bad. And also any technical legal answer these inquiries users.
It is mandatory that fixed the transfer of units between revit and 3d max.
