Hi all,
Before this broke, I could select a few objects then type into the 'named slection sets' box, shown here, to create a set. Then later come back to it, click the drop down and select my set again (very handy!) but now all i can do is click on it to see an empty drop down box, it wont let me type into it at all.
This has only recently stopped working and I would really like some help, hope you can help me! (and sorry if this has been brought up before, if so please could you link me to it as i can't find any info anywhere) Also im using 3ds max 2014 if thats of any use.
Thanks in advance for your help!
Solved by Steve_Curley. Go to Solution.
Thanks very much, that's the same issue, but sadly it looks like there's no conlusion there to how it was fixed?
I'll try resetting the preferences.
hmmmmmmm.... I've tried deleting the preferences and re-installing it, still no joy.
Going to get 2015 in a few days and hopefully that might sort the issue!
I had this same issue in 2014 recently. Reseting the theme/UI is what fixed it for me. But I had to create a new UI theme altogether.
YAAAAAAYYYYYYYYYYY Thanks all for your help, especially Steve being the first to come up with the idea, changing to another UI through the 'customize - Custom UI' fixed it! Hooray, thanks again guys!
Yea it's bizarre! But at least there is an easy enough fix for it i spose
maybe your toolbar UI config file ( *.cuix, most propably MaxStartUI.cuix ) got "touched" by the devil's hand, meaning got some error inside the main toolbar's definition structure
Hi coop. Makes sure to give Steve kudos. We want to see him reach 1000 so his avatar is etched in stone on Mount Kudos. 🙂
