3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Revit- Max design interoperability not working
7 REPLIES 7
Message 1 of 8
coadaptive
5184 Views, 7 Replies
Hi Forum,
We have a subscription to Autodesk 2014, have already installed the Revit Interoperability for 3dsmax Design 2014 update release, and still we can not use the revit to max design linking system.
We do not get an error report, instead the program gets stuck on "linking to revit" and eventually stops without doing anything.
We have tried from both programs (Revit Suite Work-flow -- to 3dsmax exterior rendering and 3dsmax design -- import link Revit) but neither of them works.
Has any one else had a similar experience, or know what the solution could be?
I have scoured the forum and online, but can't find anything on the subject (other than installing the Interoperability update, which we have already done.) Any pointers on the matter would be incredibily helpful!!! Thank you
7 REPLIES 7
Message 2 of 8
Lance.Coffey
in reply to: coadaptive
To check if the issue is with the existing project files, you could create a new 3DS and Revit project, add some simple geometry, and then try linking.
If this fails, there may be an issue with the installation of 3DS or Revit, and you could try Repairing them (in the Programs and Features Control Panel).
Lance Coffey
Technical Support Specialist
Message 3 of 8
treyjordan
I am having a similar problem.
I am running revit 2014 and wanting to link my models to 3ds Max 2013. Every time I try to link I get an error saying "the revit file failed to load." (See below.)
I have the interoperability update installed for 2013 and am going to try with the install of the update for 2014. If this doesn't work, what am I missing? Is the issue using 2014 revit and 2013 3ds?
Please any help would be wonderful!!!!
Thanks, Ian
Message 4 of 8
PROH
in reply to: treyjordan
Hi. You ask: "Is the issue using 2014 revit and 2013 3ds?"
Yes. I pretty sure that's the case. Max needs to be the same version or newer.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Message 5 of 8
j19card
So if I upgrade to Revit 2015 and keep 3ds max 2014 there's no way of making a link from 3ds max to Revit? Do I also have to buy 3ds max 2015 in order to keep my workflow?
Message 6 of 8
jadedaniel
in reply to: j19card
Hi, I am quering the same thing. Have you come to a conclusion?
Message 7 of 8
jadedaniel
Message 8 of 8
jadedaniel
"So if I upgrade to Revit 2015 and keep 3ds max 2014 there's no way of making a link from 3ds max to Revit? Do I also have to buy 3ds max 2015 in order to keep my workflow?"
