WHEN I IMPORT THE SCENE FROM REVIT TO 3 DS MAX, SOME ELEMENTS, SUCH AS TREES AND A CAR DO NOT APPEAR IN THE FILE TRASFERRED. I CAN SEE ONLY SOME CUBE.
IF I PASS FROM DWG I MANAGE TO IMPORT ALL, BUT I LOOSE SOME CARATTERISTIC SUCH AS MATERIAL. COULD SOMEONE HELP ME
Solved by PROH. Go to Solution.
Solved by jonathan.matthews. Go to Solution.
THEN I WUOULD LIKE TO SHOW YOU
- RENDER BY CLOUD (POSITION OF SILOS AND HOUSE WRONG) THEY ARE FILE SLAVE LINKED TO THE FILE MASTER
- THE RENDER BY REVIT (OK)
- IMPORTED FILE FROM REVIT TO 3 DS MAX HAS LOST CAR AND TREES
Hello, try exporting your REVIT file to AutoCAD and then link/import the AutoCAD file into 3ds Max. This has worked for myself and other customers before. Please let me know how that works for you.
Yes, I tried importing fron dwg and it could be a solution, thank. Perhaps, The problem is that i loose some information, such as materials of elements.
Don't you think so?
thanks
They are families included into revit. If you look the firrst render you can see another problem. I have a master file that include all the area and 2 slave file imported that are silos and office house. When i render by my self (using my computer) I have no problem. When i render by cloud rendering, they change position. Could you help me?
I thank you for helping me
How can i find and import object from 3 ds max
bye
In order to use the Civil View objects in 3ds Max you need to have 3ds Max Design. Based on the case notes you only have 3ds Max and not Design. I am looking into another possible solution in Revit and will get back to you soon.
In either 3ds Max or 3ds Max Design you should be able to go to Objects>AEC Objects>Foilage and be able to place plants and trees that are all ready loaded into 3ds Max. In addition you could take a look at ArchVision for thier RPC plug ins.
Best Regards.
I have managed creating AEC object. So i solved problem of tree. Now I'm trying solving car
could you help me?
I found and downloaded Autodesk_3ds_Max_2014_and_Autodesk_3ds_Max_Design_2014_English_Win_Samples_Files.
I installed them but I not able to use them
Why not? What's the problem?
You can't access them like the AEC objects. You'll need to find and open/xref/merge the files like any other Max files. AFAIK they should have been installed in your defalt Max folder - unless you specified otherwise.
Hope it helps
Glad it helped 🙂
By the way, the sample files also contains some trees - check'em out sometime. If you need some realy good looking 3D-trees, then take a look at www.laubwerk.com , they got some free samples that is integrated in Max via a free max-plugin. Try it, it's really useful.
