For some reason, I can't get this to work properly. The vector map is acting like a bitmap where it is blurry and doesn't keep a crisp resolution when I zoom in.
I loaded a vector (not raster) PDF but it seems to be acting like a raster image. I then opened the PDF in illustrator and saved it as an .ai file and loaded that into the map instead, and got the same result.
Any ideas what can be causing this?
Thanks!
-Jesse
Is it also blurry in your renders, or just in the viewport? Because viewport texture size can be set to a higher resolution.
M.
I try to use this new feature via a simple wire parameter but get a insta crash no matter what.
is there a compatibility issue with CS6 or another issue?
make a plane assing a material with this texture (attach)
right click -> wire parameter -> material -> PDF page number. Click
choose any other object and pick any parameter to act like a controller
chosse the direction (any)
click connect
crash
try on 3 diferent machines, same thing.
i not alone in this
no anwser far...
