Hi - I have been trying to find an answer for this for sometime now and wondered if anyone on here can shed any light on the matter....
I have an interior scene with an animated camera and a lot of animated lights.
I set to Project FG points from positions along path.
Divided camera path by Num. segments 49 (the animation is 1000 frames in total)
I then calculated the fg map creating one per frame.
When I come to render the scene if I leave Interpolate over n frame at 0 the scene is smooth but it will flicker as it will recalculate the fg per frame.
I know the point in in changing the interpolation over n frames to greater number than 0 is to reduce the flicker, however when I set it to 2 for example the render now is extremely splotchy.
this happens when I try rendering from 10 too (so that there are the fg file before the start to allow interpolation)
I hope this makes sense and any help would be massively appreciated!
Tim
is everything blotchy, or is it the actual lights that flicker, or is it specific areas?
it could be you have to up the image precision or the glossy samples for some of the materials
@dopple152 wrote:I set to Project FG points from positions along path.
You have the wrong combination of settings. If you Project FG points from positions along path, the you shouls only use a single FG frame.
Thanks for your reply samab.
As I have an animated camera, I have to Project FG points from positions along path....
but I thought if i have animated lights and objects in the scene as well, I need to use a fgm per frame, not just a single fgm.
I thought a single fgm shouldnt be used if you have animated objects or lights.... (as stated in the mode pull down menu)
@dopple152 wrote:Thanks for your reply samab.
Correct, don't use a single FG map with animated objects and lights. But also, don't use point along a path with multiple FG maps.
So if you do have moving lights and objects, use camera position, not along the path, and use multiple FG maps, interpolate them if needed to reduce flicker.
What project along path does, if you watch it render, is render a number of sampled frames into a single frame. So rendering multiple frames of this is pointless, because thay are all the same.
'Best for stills', maybe it should read 'Best for stills, and scenes where objects and/or lights move about regardless of whether the camera moves or not'.
Or at least 'Best, but not exclusively, for stills'.
Yes, that can be mis-leading, you have to read to long version in the documentation to understand it properly.
Hello mate - did you find the answer to this one?
I'm in the same boat as you and I'm sitting in the office at 9pm on a Friday night desperately trying to find the answer!
Did you suss it out, if so could you help me out?
Also - if you can't give the whoel answer now, a reply to let me know would be helpful so I can go home!
cheers
Did you work it out in the end?
Sorry i didnt see your post until this morning?
I ended up calculating FG points along camera path and using one file per frame (as the lights were changing colour throughout the animation) this produced the best results. I could then interpolate over a couple of frames to smooth outnte result further.
Hope this helps and its not too late!
heers for the reply - but I'm not sure how that would sonve the problem.
Your blitchiness in this case was caused BY interpolating frames... how did you get rid of that blotchiness?
I experienced the same with an opening door, best in this case has been to enter "0" at "Interpolate over N frames".
I noticed with 3dsmax Design 2015 somehow flickering wouldn´t occur like in previous versions.
That's no solution, because if you dont interpolate over the frames you're going to get flickering GI - that's the whole point of having the animation mode.
That´s been how I noticed it in previous versions. Though, in a current project with fast movements I had to minimise the Interpolation over frames to "0" otherwise their would have been a dragging lag within the animation. Astonishingly there hasn´t been any flickering anymore. This already worked in several scenes I applied this setting. Might not work everywhere but it certainly worked within the scenes here.
Might be important to mention, I rendered with prerendered singleframe FG maps (naturally) and calculated a new GI map for every single frame on the fly during mainrendering.
