Hi otaku330.
Dont panic just because your hardware isn't on Autodesk's list. It doesn't mean that it won't work, it simply means that it hasn't' been tested.
Your system spec reads: "Total amount of system memory 2.00 GB". This is way to little. Acording to Autodesk, the minimum requirements for 3dsMax2012 64bit on Windows 7 64bit Professional is 4GB (8GB recommended). This only goes for smal projects (typically fewer than 1,000 objects or 100,000 polygons). Larger project requires more RAM.
I believe this is your major problem - secondly check up on your Graphic Card + driver.
Hope it helps
