Hi Guys,
We have a problem with Backburner 2014.
We have about 80 machines using backburner for rendering. We use the description in the Server to label the computers and to know where they are physically. Then we enable the Description column in the Monitor.
This worked just fine in the old backburner 2008, but we recently switched to 2014 and the Monitor is lagging a lot when the Description column is on. It takes about 10 seconds for the Monitor to refresh. When the Description column is disabled everything is back to normal and working perfectly.
The problem is in the Description column specifically. Any other column works fine, even the IPs.
Any ideas how to fix it?
REDVERTEX
There appears to be small issues cropping up with 2014/2015 and backburning but I have not seen this one.
Please report this as a big at http://download.autodesk.com/us/support/report_a_bug.html?SelProduct=3dsMax so that it can be looked at. Make sure that you provide a detailed description of how to create the problem so that it can be reproduced.
