Something very strange occurs:
I have an animated self illum. shader progressively lighting up but, when I render my anim with "active time segment", the self illum shader is not glowing and remains dark.
and when I render with "single" then everything returns fine and the self illum is working as it should.
I mean, if I render a frame where the shader should be glowing (55 for example ) with "single", it works. And when I check the frame 55 rendered with active time segment, the shader is black (not glowing).
I don't change any param when doing the two renders
Does anyone knows what's going on?
Thank you
