Area :: Header
Interested in making Indie games?
Register for a Meet the Experts webinar with Digital-Tutors today!
Discussion Groups
3ds Max / 3ds Max Design General
Darex
3ds max 2013 IBL Mental Ray Black Render
62 Views, 13 Replies
04-25-2012 03:32 AM
Heya
I was wondering how on earth do we enable IBL lighting to work inside 3ds max 2013/2012?
Heres my quick workflow
1. Create omni light, disable it to get rid of 3ds max default lights.
2. Go to 8 > Insert Environment / background switch texture.
3. Put Bitmap HDRI inside environment.
4. Disable GI
5. Assign A&D shaders with no reflection just pure gray
6. Render = black render.
And thats it, I did try Optimizer v1 it don't work. I try tons of other things to get it to work but nothing seems to work...
Can any1 help me with it please?
Thanks, bye.
Please use plain text.
Active Contributor
Animatik
Re: 3ds max 2013 IBL Mental Ray Black Render
04-25-2012 04:26 AM in reply to: Darex
You have to create a skylight and put your hdri map to Sky Color
Distinguished Contributor
ivan_iliev
04-25-2012 05:10 AM in reply to: Darex
I’ve no idea what you are after using this particular workflow, but to use HDRI image as a light source, you need a sky light with “Use scene environment” option activated.
ivan
Member
fabiodacosta
04-25-2012 06:03 AM in reply to: Darex
I beleave his intention is to use the IBL feature that's part o Mental Ray for years, but Autodesk refuses to expose it to customers.
I would like to know how to enable this feature too.
Beauty is on the eyes of the beholder.
Darex
04-25-2012 06:46 AM in reply to: Darex
I want to use the proper mental ray IBL which uses importance sampling to sample the HDRI to get better results hard shadows etc etc.
I'm hopping I would be able to map this HDRI to custom looking object (sphere with flatten bottom ) to simulate floors and other things. So its not just infinite sphere..
jeff
04-25-2012 08:18 AM in reply to: Darex
<edited> The mr Options Manager script has been updated so use it instead of what I had outlined here before it was updated <JP>
Darex
04-25-2012 08:33 AM in reply to: jeff
Heya
Thanks Jeff I think I also emailed u at some time yesterday.
In any case thanks for help, will dig in it. Its so unprofessional of autodesk to do this thing and expect people to magically know those things out of thin air. On top of that they asking 45% extra for their max subscription !
Anyway will work on it tomorrow night once I get home, I do have Thorsten script but it wont work in max 2013 since they hanved folder name from mentalimages to NVIDIA (lol)
From a side note are you now using fully Iray or did u move to Vray ?
Thanks bye.
jeff
04-25-2012 09:46 AM in reply to: Darex
Darex
04-25-2012 03:16 PM in reply to: jeff
Hey Jeff
Thanks for ur help ! Ure live savier.
But I still cant get it to work - which is weird because now it should work - I only dont use unindefinied sampling(or whats its called..)
In any case I get this warn and pretty much black render
PHEN 0.19 1028 MB warn : IBL shaders should be applied to a VISIBLE user area lights to work optimally.
It try to render with HDRI but I still get black render or bugged... arr gotta work on it for a lil while longer.
EDIT: I got it to work. Its quite noisy and bad but I'll work on it tommorow. Thanks Jeffa again for help ! Btw the hemisphere for Iray from ur web, will it also work in mental 2013 ibl?
Thanks, bye.
jeff
04-25-2012 04:28 PM in reply to: jeff
Yup, I believe you'll have to use unified sampling in order to get the best results from this particular IBL setup.
AFAIK the hemisphere mode in iray doesn't work with mental ray. I have no idea if they plan on implementing that into mental ray or if there's an existing shader/mode/widget/spell that will produce that in mr today. :smileyhappy:
