If I can't click on assign materials what have I done wrong?
You may want to switch your material editor to slate instead of compact. I find that the slate material editor is mor intuitive when you are first starting out than you can simply wire the bitmap to the difuse channel and than drag the materail out to the object from the output. See attached
